01-19-2019 06:55
01-19-2019 06:55
About a month ago, my wife and I replaced
our Blazes with Versas... Mine works sporadically, but often, when I go to syncing it with my iPhone 8 Plus, it just days Looking. My Blaze was connected all of the time, and I only replaced it because recently it showed signs of wearing out after 3 years. The Bersa does sync sometimes, but other times it won’t. Is there a problem with the Bluetooth on this thing? I’ve read a number of similar complains, and I’ve done all the things they suggest.
Best Answer01-19-2019 20:27
01-19-2019 20:27
@schaefman it got buggy after recent iOS updates. It will get ironed out sooner or later with the upcoming fitbit mobile app updates. For now, you can try this to restore the bluetooth connectivity:
If you have Wifi set up, go to Fitbit mobile app and remove it, then sync your Versa. I noticed that it causes issues for me. If you have other Bluetooth devices paired with your phone, forget them. One of them might be causing issues. Also, make sure All day sync is enabled.
