05-04-2022 11:15 - last edited on 12-18-2022 19:58 by
Did I just buy another fitbit where I can't turn on a water lock manually? I just bought a Versa 3 and I wear it while I Box/Kickbox. My glove is constantly turning off the exercise on my Versa 3. This wasn't much of an issue with my Versa 2 because it required two screen presses to pause or end an exercise. It did happen once in a while but not very often. My Versa 3 is basically worthless for boxing which is one of my primary forms of exercise.
I figured that a water lock was an easy enough feature to implant that it would be included on the Versa 3. Did I make a mistake or am I simply not finding a feature that is there?
05-04-2022 20:39
05-04-2022 20:39
I’m aware of is if you choose “ swimming” as the exercise
21:02
11:05
05-04-2022
21:02
11:05
Best Answer05-05-2022 03:47
05-05-2022 03:47
Use the swimming excersise feature. Double tap the button on the side to exit the swimming excersise
Best Answer05-05-2022 07:35
05-05-2022 07:35
Best Answer05-05-2022 08:59
05-05-2022 08:59
Hi Mavii, I’ve had these problems when weight lifting. It is so annoying!
I found these suggestions for a workaround. Give these a try. Sometimes they work sometimes not. Maybe the next gen will have a lockout feature.
https://www.myhealthyapple.com/fitbit-keeps-pausing-during-workouts-lets-fix-it/
