March Blossom clock face
The weather will not update on the March Blossom clock face, suggestions?
7 REPLIES 7
I'm gonna guess you need all-day sync turned on in the app so that your phone can send the weather info to your Versa.
I thought that too but it's on 😞
When did you install it? I noticed in the gallery that it says there was an update on 4/19 to fix a weather app problem.
Thank you for the feedback. Make sure your phone is sync with the watch, that you have gps permissions on the phone and internet connection. Try to reboot the watch.
This should work. Sometimes an error can happen when the phone is trying to send new data about the weather. This error can be cause by no internet connection.
You should have mobile data or wifi on the mobile because the clockface needs to fetch the temperature. If you don't have internet connection you will have '--' meaning no data available , this can happen from time to time.
If you have internet and GPS connections and the watch is synchronized with the phone, a restart should help.
P.S. All day sync means that the phone will get for example the steps and other information from the watch to your account only when they are synced. All day does not mean there is a connection between the phone and the watch so that the watch can receive the weather.
My watch got all messed up when i put this face on. The steps were 12300 on my watch but my phone app said 12677. My date was wrong at firstbut when I updated that seemed to fix it. Then even though the look at watch feature was turned on it wasn't lighting up without me touching the watch. I really wanted to love this face as it is so pretty.
Indeed there waa a problem with the date but it was fixed. Regarding the steps difference I don't think that your watch synced with your phone. The clockface displays exactly the Fitbit stats from the tracker. The watch turn on only when you move your wrist forward to look at the watch from what I know and this is happening with the March Blosson clockface. Sorry if you had a bad experience with it.
Kind regards,
Eduard
Hello,
Just made sure of all these mentioned settings are enabled, rebooted and the weather still wont show up. Any other idea what might be the issue?
