Hi, unfortunately Message+ is not an app supported by Fitbit. If you want this feature enabled/developed in the future for the Versa, post your question in this board. On the top of the screen, you will find "Make a new suggestion", click that and post post your request.
Best Answer@Nicolel123 Message+ fix was released with Fitbit mobile app build 2.73 I believe. Ok, let's take a look at your settings. A few questions first, are you able to receive other notifications? Does your Versa sync without any issues? For now, let's try this:
Note: In case you can receive a text notification but you do not have option for quick reply nor can you read it - Make sure that Preview of the message is enabled - go to your messaging app settings, and enable Preview on the screen (please check this Verizon help article). By default, Samsung phones have it disabled, which means message can't be seen on the phone's screen and Versa cannot read it.
Hope that helps!
