01-10-2020
08:14
12:27
DavideFitbit
01-10-2020
08:14
12:27
DavideFitbit
My Fitbit is stuck on 8 degrees Celsius. After several attempts to change to Fahrenheit and resync it still hasn’t changed. What do I have to do to keep what I update?
01-10-2020 09:25
01-10-2020 09:25
Hi @darfleck , try this:
1. Restart your Versa 2 three times in a row by long pressing the left button untill you see the Fitbit logo and release the button
2. After that go within the Fitbit app to Apps - My apps and scroll down to weather and press the settings icon on the right side of it. There you can change Celsius to Farhenheit of v.v.
3. Sync your Versa 2 with you phone.
Hope this helps in solving your problem, regards kuzibri
01-10-2020 10:05
01-10-2020 10:05
Thanks for the advice! Unfortunately it didn’t work. Still stuck at 8 degrees Celsius😢
01-10-2020 10:09
01-10-2020 10:09
Are you using a Fitbit Clock Face or a Third Party Clock Face? regards kuzibri
01-10-2020 10:46
01-10-2020 10:46
Fitbit
01-10-2020 10:57
01-10-2020 10:57
Hi @darfleck , I'm afrais that the only way to solve this problem is a Factory Reset and after that setup your Versa 2 within the Fitbit app as a new watch, sorry. Regards kuzibri
01-10-2020 11:04
01-10-2020 11:04
Thank you for trying to help!
01-10-2020 11:17
01-10-2020 11:17
You're very welcome. If you decide to perform a FR, sync your Versa before that with your phone, otherwise you will loose your unsynced data. Regards kuzibri
