02-09-2020 12:56
02-09-2020 12:56
Setting up a new Versa Lite on my Motorola Droid phone (v6.01). The app is loaded. It is seen on Bluetooth but will not connect in setup.In the setup process it says it sees the device then goes to a check mark and at the bottom it says "connecting..." and never moves from there. It will say to restart the device. I check the Bluetooth connections and it shows up there.
I have rebooted the device (hold button for 10 seconds), turned off Bluetooth on again, rebooted the phone. Removed and re installed the app. All I get is the same error.
Can't seem to paste an image of the error.
Best Answer02-09-2020 13:55
02-09-2020 13:55
Your phone is probably not on the Approved Devices list so may work for some functions and not others.
