01-09-2019 22:07
01-09-2019 22:07
I noticed today that my watch was no longer notifying me for txt messages, calls, etc. I’ve had my versa for about 8 months and never had this issue. Any suggestions? I shut off my watch today to see if that helped but it didn’t. All notifications are set to on.
Best Answer01-10-2019 03:41 - edited 01-10-2019 03:42
@Kirstenjane17I've fixed mine. I tried the following:
1) restarting the versa by holding the left button and the bottom right together until the fitbit logo appeared
2) checking the setting on the phone (I have an iPhone so for example for messages its settings>notifications>messages and then you need to have 'Lock Screen' and 'Banners' selected).
3) Check the settings on the Fitbit app (select the button on the top right and then you versa then check settings are on.
4) ….and this is the one that got me. If you hold and press the button on the left of you versa if brings up the quick settings screen and on here I had accidently turned notifications off. Turn this on. I think this can get easily knocked.
hope that helps.
01-09-2019 22:09
01-09-2019 22:13
01-09-2019 22:13
I had this same issue, spoke to customer service and the woman said that the push notification feature has been taken off! I’ve filed complaints. As I’ve only had my Fitbit for 2 weeks and that feature was 90% of my reason to purchase one, I’m very disappointed.
Best Answer01-09-2019 22:31
01-09-2019 22:31
@Marrrmaduke I have an iPhone 8 Plus with iOS 12.1.2. I’ll try rebooting both and will let you know
Best Answer01-09-2019 23:19
01-09-2019 23:19
@Kirstenjane17, I hope that’s not the case. I really like the notifications
01-09-2019 23:19
@Marrrmaduke It didn’t work 😞
Best Answer01-10-2019 00:20
01-10-2019 00:20
Hope they haven’t taken them off for good if they have APPLE watch here I come
01-10-2019 00:26
01-10-2019 00:26
Contact customer service and file a feedback or complaint form. Surely if they receive enough complaints they will fix the issue. Otherwise I’ll be going for an Apple Watch also.
01-10-2019 02:45
01-10-2019 02:45
Surely this can't be true? If it is I will be fuming. I got mine for Christmas and the notifications worked for a few days and then stopped. Settings all appear to be correct.
01-10-2019 03:18
01-10-2019 03:18
@Nicola575 That’s the same as what mine has done. I’ve only had mine a few weeks and it’s been inaccurate, had problems syncing, now no notifications. I’ll be seeking a refund.
hope that helps.
01-10-2019 03:51
01-10-2019 03:51
I’m glad you’ve managed to get it working for you.
I went through and tried all the troubleshooting with customer support over the phone and the issue is that the notifications are there (when you swipe down on the clock face) but there’s no alert/vibration/light up/preview or anything when the notification first comes in. What’s the use in having a notification if your not notified of it. ☹️
Best Answer01-10-2019 04:14
Bronze Community Members are highly active users who have shared their knowledge for the betterment of Fitbit products and services. Learn more
01-10-2019 04:14
Are the lock screen and banner options required for notifications on my Versa now? It would explain why I haven't been getting Whatsapp notifications but have from other apps.
If that's so I'd very much like it put back to the old way. I have them off on my phone because it's nobody's business what messages I receive but I do want them on my Versa.
Best Answer01-10-2019 04:36
01-10-2019 04:36
I don’t think you can have notifications ‘off’ on your phone but ‘on’ on the versa. I think they have to be turned on on your phone which is then pushed to the versa.
Best Answer01-10-2019 04:43
01-10-2019 04:43
That’s odd as it sounds like the notifications are on to a degree. The only other thing I can think of are if you swipe right from the clock face and select settings, then notifications, is it turned on for During exercise, sleep etc?
Best Answer01-10-2019 07:15
01-10-2019 07:15
@Nicola575 I just saw that my notifications were turned off when I pressed and held the left button. It has always been checked. I had checked all other settings and shut off my Versa but didn’t check that. I’ll find out on my next msg if I get the alert. Crossing fingers 🤞
01-10-2019 09:03
01-10-2019 09:03
Tried all the solutions still not showing notifications
01-10-2019 13:27
01-11-2019 00:52
01-11-2019 00:52
I know how to set them up,,,still not working
Best Answer01-15-2019 15:21
01-15-2019 15:21
That’s crazy. I have been in contact with customer service for this issue. They have told me the problem is with my phone then it was the app. They make me go though a ton of steps every time. They have never told me this but it makes sense. The notifications is a huge reason I have it. It’s very frustrating that they just keep giving me the run around on this, when the issue is obviously their problem. I hope they fix this cause otherwise we will return them and go with the Apple Watch.
