08-07-2018
01:49
11:11
AlejandraFitbit
08-07-2018
01:49
11:11
AlejandraFitbit
My Versa is synced properly. But I am not getting any notification on my device at all. I have restarted the device, reinstalled the app. No luck. I am using a S7 edge. I have tried several solutions in the forum. But none of them are apparently working.
11:13
11:12
08-08-2018
11:13
11:12
It's great to see you around @Sawan007.
Thanks for troubleshooting this by yourself, I am glad to see here that this issue has been resolved and appreciate the tip provided in order to fix this.
Let us know if you need anything else. ![]()
The above solution for the aforementioned person is not my solution as my notifications are turned on on my watch. I reviewed the help on making sure that your phone (Samsung S9) has all the permissions to allow the push of data (phone, SMS, etc.) and from what I can tell all of my settings are correct. I am not able to locate the permissions for each of the apps to send their notifications on my webpage. I have never received a phone notification since I bought my Fitbit Versa a few months ago. Going to need some more troubleshooting methods.
06:40
11:12
08-09-2018
06:40
11:12
Great to see new faces @RichelleAura, welcome!
If you are having issues with your notifications, I recommend taking a look at the help article My Fitbit device isn't receiving notifications from my phone and follow the instructions provide there.
I hope this helps, let me know the outcome. ![]()
