05-11-2018 20:11
05-11-2018 20:11
I just got my versa 2 days ago and my messanger plus app will not give me notifications on watch. I have called fitbit several times and have gone through many different steps. They finally emailed me and tols me i am.just goong to have to wait for an update on versa when they get this fixed. They advertise that it is a feature and is frustating that it will not work.
Best Answer05-12-2018 12:58
05-12-2018 12:58
I'm having the same issue, but only since last nights update to the newest software. It was working fine until then. I also have messenger +. I spent over an hour on the phone with fitbit twice today and even went as far as to uninstall the app and do a factory reset on the versa. I still get email notifications, FB messenger notifications, etc., just no text messages. They finally ended up telling me they are having some issues with the messaging and are working on it...
Best Answer05-12-2018 15:26
05-12-2018 15:26
Best Answer05-12-2018 15:30
05-12-2018 15:30
Many members have reported that message+ does not work because it doesn't use the same protocol for text retrieval within Android. Not sure if someone tried this, but set your messaging app as whatsapp or something else and select message+ within app notifications section instead in the fitbit app.
Best Answer05-14-2018 14:09
05-14-2018 14:09
Best Answer05-14-2018 14:16
05-14-2018 14:16
A temporary fix is to install the app "Fit Notifications" on your phone. Then you can use Message+ on your phone, and the notifications on your watch need to be set to "Fit Notifications." I do receive messages on my watch now from Message+, but the quick reply option isn't there.
Best Answer05-14-2018 14:28
05-14-2018 14:28
