06-05-2018
08:49
04:30
06-05-2018
08:49
04:30
Hi there @Versa13, good to see you here in the Fitbit Community. After reading your post I saw your workout is showing distance despite this is not a running activity.
I would recommend to reset your Versa watch. For more details please use this information: How do I restart my Fitbit device?
In addition, try to log out from your Fitbit app and reset your phone. Once you have finished, go back and log back in and try again. Most likely this fix will not resolve already synced activities, but it may prevent the issue in future exercises.
I'm wondering if you are using "workout" to track your Bootcamp exercise or are you specifically using the "Bootcamp" shortcut? The reason of my question is to learn how this issue is more often to happen.
To learn more about this, please use this article as a walkthrough: How do I customize the exercises on my Fitbit device?
Keep me posted how it goes. There are other reports regarding this behavior.
Best AnswerIs there a bootcamp shortcut? I didn’t see that as an option!
You can set it up on your device you can have 7 shortcuts. So you might need to delete one
But it sounds like workout might be the better option frorm stated above
Might want to try both
Wendy | CA | Moto G6 Android
