12-25-2020 13:56
12-25-2020 13:56
I got this today. Everything works except text messages. I have done everything it says for trouble shooting and still nothing. I have an iphone7.
12-25-2020 19:06
12-25-2020 19:06
I'm using a Samsung S8 and have had the same problem for a couple of months. Not sure what they're doing about this but hopefully it gets addressed soon....
12-25-2020 19:13
12-25-2020 19:13
Yea like I’m getting no notifications from Facebook or Snapchat or text, but I do get phone calls,
12-25-2020 20:29
12-25-2020 20:29
Same exact thing with me but I have an iPhone 11. What is going on?!
12-25-2020 21:07 - edited 12-25-2020 21:08
I found something in the help section under Notifications and this seemed to do the trick.
1. In the Fitbit app go to Notifications and turn off all notifications.
2. Restart phone
3. Go back into Fitbit app and turn on all of the notifications.
4. Resync your device in the app
When I went to Notifications in the app (after resyncing in step 4 above) it started asking if Fitbit could access my contacts, etc., etc. I said yes to all of the prompts.
My son sent me a text as a test and it worked.
Hope the above works for all of you. How long it holds up remains to be seen but so far so good...
12-26-2020 06:26
12-26-2020 06:26
12-26-2020 06:29
12-26-2020 06:29
12-26-2020 10:01
12-26-2020 10:01
I tried it also. Still didn’t work. 😕
12-27-2020 10:42
12-27-2020 10:42
Was having the exact same issue and this worked for me. Thank you!
12-27-2020 18:43
12-27-2020 18:43
Same problem except my versa 2 doesn’t keep a good wifi connection and says the wifi IP is off. I did all the troubleshooting there is and still nothing. I even changed routers and it has a hard time connecting to the internet. I’m returning, sadly. 😢
01-21-2021 17:42
01-21-2021 17:42
I have an iPhone 8 and this worked for me after I had tried everything else. Thanks!!
01-22-2021 12:48
01-22-2021 12:48
Same here!
