02-20-2020 23:52
02-20-2020 23:52
Hi I’ve had my Versa 2 for a few weeks and all was good. Then suddenly this week it’s stopped tracking my sleep. Battery is never below 30% and the green light is flashing. I did turn the heart rate off and on and restarted the Fitbit and that worked yesterday. But today it’s not tracked my sleep again and have tried this trick and it’s not worked. What’s going on 😫😭 I don’t want to have to restart daily that’s not ideal I need a fix!!!!!
02-21-2020 05:09
02-21-2020 05:09
Same. I have only had my Versa for two days, and sleep stages worked the first night, but not last. I did nothing different from one night to the next.
02-21-2020 10:16
02-21-2020 10:16
If you go into your profile and click on your device, what does it say the firmware version is? For example:
(Firmware Version: 00.00.0.00)
02-21-2020 10:19
02-21-2020 10:19
It says version 70.7.21
02-21-2020 10:19
02-21-2020 10:20
02-21-2020 10:20
02-21-2020 10:29
02-21-2020 10:29
Did you update very recently? The new software may be still a little buggy in the occasional device. You could try removing the Fitbit from your account and re-adding it back.
02-21-2020 10:33
02-21-2020 10:33
I only recently bought it.. not sure I’ve done any updates.. are there any hacks that could make it work.. my boyfriends isn’t syncing either we bought them the same time
02-21-2020 11:15 - edited 02-21-2020 11:17
If you only recently bought it I'd suggest returning it for a refund, if you can't return it then you'll just have to do this:
Tell customer support your problem, what device has said problem, and the current firmware version.
If sleep is the only thing wrong you could use the device till Fitbit provides a new update that addresses the issue.
There aren't really any hacks/workarounds available for Fitbit devices right now.
02-21-2020 11:43
02-21-2020 11:43
Returning it for a refund?! So what it’s just useless then and completely not worth £199?! They can’t seriously be the case
02-21-2020 11:58
02-21-2020 11:58
If you can get most of your money back it's the safest way to deal with a failing Fitbit. Fitbit doesn't make easy to fix devices, they're great when they work and terrible if they fail. Unfortunately Fitbits warranty doesn't cover software failure, even though they cause the failure 75% of the time.
02-21-2020 12:22
02-21-2020 12:22
Same version - 70. Etc.
Checked latest S/W version over the last 3 days - no updates.
Have talked to HD regarding Sleep and BP data multiple times - Same answer. Two days ago HD sent complaint to Engineering Dept - including a Reference #. No response from ED. Called HD moments ago - recommended usual steps: reboot watch reboot phone. Reinstall app. Etc - etc
All of which I have done two days ago while talking to HD Supervisor - Brian. And two days prior- Sup Harland.
What does anyone suggest?
Thanks Woody
