Hey...
I have had my Versa for about 6 months and it did work perfectly until yesterday.
I dont get calls and notifications. If i go to my Versa Notifications my text will be there but it did not notify me and i dont get calls.
I have restart my versa and phone.
All my notifications is on.
If some one can hellp me pls.
UPDATE: I just chatted with fitbit support and they solved this problem. Here's what we did:
I feel like I tried everything in this list on my own except restarting the device, so maybe that did the trick, or perhaps the order of operations matters. ¯\_(ツ)_/¯
I asked what caused this problem, and the agent said "It's possible the Fitbit Versa's notifications just needed a refresh," which isn't very satisfying. But they are working again. I hope this isn't something that needs to be done regularly.
Best Answer@JSR93 Are the notifications ON on Versa itself? Please press and hold the left button to access quick menu. Toggle the notifications there OFF/ON several times and reboot your tracker by pressing and holding the left and bottom right buttons until fitbit logo appears.
I am having the same problem. I bought my Versa two weeks ago. Notifications worked flawlessly from Day One until yesterday. I have not made any changes to my phone to cause this issue -- notifications just stopped working. The app is still syncing my fitness data.
I have tried:
I cannot think of anything else to try.
I bought the Versa to replace a Pebble Round, which reliably provided notifications. Notifications are 95% of the reason I got a Versa. If this cannot be fixed I will be forced to return the device as it doesn't do what I need it to do. Are there further suggestions for how to fix this problem?
Best AnswerUPDATE: I just chatted with fitbit support and they solved this problem. Here's what we did:
