Hello all!
I have a 3 month old Versa - phone is sync'd to versa and all notification options are on.
If my battery on my Versa is low will I still receive notification like calls, text etc?
Thanks!
Hi, AFAIK you still will get notifications, although when you get a message from Fitbit that your Versa's battery is low, I strongly advice you to put your Versa asap in the charger to prevent the Versa's battery from completely draining.
