02-25-2022
23:42
03:49
02-25-2022
23:42
03:49
My notifications just stopped showing up on my versa watch and I can't get them back. Any help?
02-26-2022 04:08 - edited 06-10-2023 10:25
Hi there, @KaylaHigg. Welcome to the Community Forums. Thanks for sharing the details about the issue with your Versa.
I've seen you contacted our Support Team after posting here and they've already assisted you with this matter. If you still need help, please feel free to contact them back so they can continue assisting you.
Best Answer02-26-2022 07:02
02-26-2022 07:02
Same thing with mine
02-26-2022 07:09
02-26-2022 07:09
@ronnielonoff on Twitter and send a message to your support team…but no answer!!!
Best Answer02-26-2022 09:40
02-26-2022 09:40
I had a Garmin for 5 years prior to the Fitbit Versa 2 and never had an issue. If Fitbit Support cannot be of assistance, I guess I will return this and go back to Garmin. It’s all on Fitbit at this point!
Best Answer03-04-2022 16:16
03-04-2022 16:16
If your issue was resolved, can you please post your solution?? My watch quit notifying me 2 days ago and I need help.
03-10-2022 12:25
03-10-2022 12:25
Best Answer03-11-2022 06:04
03-11-2022 06:04
My problem is now solved. I followed instructions someone posted when using huawei phone. now working and receiving all notfications😊🤞
Best Answer03-11-2022 06:11 - edited 03-11-2022 06:12
Can you post the link to the steps, or share the wealth of knowledge??
I flat out quit wearing my watch since I got tired of removing it from the app, deleting the app, powering off the phone and watch, re-syncing it all again and again.
Best Answer03-11-2022 14:29
03-11-2022 14:29
It's usually to do with battery saving functions in your phone, you need to dig into the fitbit app settings and make sure any battery saver options are turned off I have found. Usually a long press on the app then you can select app settings. Unfortunately with my Xiaomi phone with the new Android 12 the battery saver feature isn't shown in that menu any more and I had to dig deeper into the phone settings to find it for the fitbit app
