01-10-2019 19:14
01-10-2019 19:14
Is anyone else having an issue where their notifications don’t all clear? At first it was just the very first one I got but now it seems one every day stays on. If I pull down the notifications I have one from Christmas Day (when I got it) and random days after that I have seen and tried to clear many times!
01-11-2019 07:15
01-11-2019 07:15
Hi there yes I did and rebooting it clears it . Hold left and bottom right button in Fitbit until Fitbit icon comes on and should take care of it
01-10-2019 19:38
01-10-2019 19:38
@jessdreamy known issue. Reboot your phone and Versa. If this doesn't help reinstall Fitbit app.
01-10-2019 19:49
01-10-2019 19:49
01-10-2019 19:52
01-10-2019 19:52
@jessdreamy Press and hold the left and bottom right buttons until Fitbit logo flashes. Welcome to the Fitbit family!
01-11-2019 07:15
01-11-2019 07:15
01-11-2019 07:16
01-11-2019 07:16
Yes it works and if it doesn’t call Fitbit they will help
01-17-2019 19:48
01-17-2019 19:48
Thanks, that just worked for me, too. This is a new issue for me. I hope Fitbit resolves it quickly.
02-07-2019 09:02
02-07-2019 09:02
Hi,
First off thanks for the reset solution it works.
However, why is it required? Please Fitbit fix
02-07-2019 14:28
02-07-2019 14:28
Leaving All-Day Sync on helps avoid the issue completely.
02-07-2019 15:33
02-07-2019 15:33
Hi, maybe you do not suffer from this problem that's already mentioned by a lot of users, but All Day Sync is not the solution for this problem unfortunately. Only restarting several times is the real solution.
02-07-2019 16:03
02-07-2019 16:03
I do have the same problem. Once you get them cleared, the way to prevent them from recurring is to turn on All-Day Sync.
02-07-2019 16:06
02-07-2019 16:06
I have All Day Sync also enabled, but - in my case - it does not prevent this issue, sorry.
02-07-2019 17:03
02-07-2019 17:03
Actually, @Kalnel is right. Anything that helps stable sync (and that's All-day sync) and bluetooth connectivity has impact on that issue. Same as rebooting, repairing and sometimes even clearing the cache. These tricks may not eliminate the problem permanently, but definitely help reduce it.
02-07-2019 20:00
02-07-2019 20:00
Yup. Nothing works for every person 100% of the time, but I can say that since I turned on All-Day Sync four days ago, I haven't had a single notification get stuck/fail to clear. They all sync in real-time with my phone now. I get at least 50-100 notifications a day, so that seems pretty robust to me.
I am taking a hit on battery life on my phone and the Versa, but nothing major.
05-14-2019 23:52
05-14-2019 23:52
Thank you! This really helped.
05-15-2019 03:58
05-15-2019 03:58
Glad it worked , I have to do it many times so I will most likely be calling Fitbit
05-15-2019 05:24
05-15-2019 05:24
Hi yes it does work but I shouldn’t have to be doing this a lot so in this case I will have to contact Fitbit
07-30-2019 08:31
07-30-2019 08:31
Thank you!! Last time this happened I had to reset everything on my fitbit!
07-30-2019 09:20
07-30-2019 09:20
08-02-2019 10:41
08-02-2019 10:41
Neither of these fixed it for me
