07-28-2022
09:55
17:44
07-28-2022
09:55
17:44
I have tried most of the suggested fixes but nothing worked for me. I am using a Huawei P10 lite phone and my notifications were working perfectly until last night. Now I cannot get them to show on my tracker and calls are also not coming through on my tracker. Can Fitbit please fix this as soon as possible.
It seems that with each update (which is supposed to fix an issue) more issues and problems are created and this in truly annoying.
Last night? The last app update was 5 days ago. Were there any other updates to your phone? Android update maybe? Also, check out this article that talks about Huawei phones. It's possible a phone update borked it.
Hi @AndreaNAM - there are many reports of this bug in the latest Fitbit App version. Just in case check your Quick Settings to make sure that neither Sleep nor Do not disturb got turned on.
@AndreaNAM- unfortunately there is nothing you or others can do, you have to wait for Fitbit to release a corrected version of the Fitbit App.
