Original Clock Face
I have changed the clock gave on my Versa but can’t find the original or default face anywhere. Anyone have any ideas?
24 REPLIES 24
If you do a factory reset everythjng will go back to the default (but then you have to set it all up again!)
Community Council Member
Helen | Western Australia
I think it's the one called "Layers". In the app on my phone:
  1. Click on Account icon, the little box icon on the far right at the bottom
  2. Click on "Versa"
  3. Go to "clocks"
  4. The first lot is "By Fitbit"; click "View All" on the right
  5. Scroll down to the bottom and "Layers" is the one on the bottom right.
It might be different for other people.
Mine came with the "Light" clock face which is face #9 located where Suzy described above.
This was really Helpful. This is the correct way of getting back to the original clock face
Thanks - just received mine from Santa and this was helpful
Hi. the Light Clock Face comes with the Versa Special Edition watch.
This worked for my ionic , thanks .
OMG. That was the perfect solution. Thank you so much for the detailed answer!!!
For the Versa 2, it is Waveform.
Thanks a lot!
If it’s the original you want, then it’s probably under “by Fitbit” and it says layers
Versa Lite users do the same and find trace
Thank you, it help me a lot.
which is the light clock face? And with the versa 2 special edition can you receive texts ? Mine did show that I had a text but now it doesnt show it..
Lite clock face is the one that says trace under by Fitbit and I’m sure that u should receive texts on special edition Fitbit versa 2. I mean it is special edition so u should get more advantages than disadvantages but honestly I’m not sure since I don’t have it
It's called "Trace".
I wanted it back too. So happy to find it.
Thank god for you! I was worried I was gonna have to do a factory reset... which I couldn’t be asked for! 😁
No.... just no....
Moderator edit: merged reply
I think its called Trace. I saw someone say it was Layers, but Trace looks more like the original.
The original clock face on the first Versa was definitely Layers.
Do what you want, but Trace is the original for mine.
