07-17-2018 18:59
07-17-2018 18:59
Hello! I am new to the Fitbit. I generally run and use pace to train (on an old Garmin). I work in Kilometres..... all the Fitbit is giving me is feet and inches for pace. I can’t find any solutions in my searches.
Many ideas would be fantastic.
Best Answer07-17-2018 21:59
07-17-2018 21:59
Hi @Kya007
You'll want to go to the settings section and switch inches for kilometers - click to go there
See if that works for you.
07-18-2018 02:21
07-18-2018 02:21
Best Answer07-18-2018 07:45
07-18-2018 07:45
If you select cm, then you will see kilometers. If you select inches, you get miles.
Try that and see if you get kilometers.
Glad you're with us @Kya007
07-18-2018 15:38
07-18-2018 15:38
