09-15-2018 07:25
09-15-2018 07:25
I have a iPhone 6 on straight talk. I’m wondering if the Fitbit versa will work with my phone?
Best Answer09-15-2018 07:55
09-15-2018 07:55
Should, even the basic plan has 100MB data plan to share the app data with our servers. Each transmission is pretty tiny. Be aware installing the App will take hooking to itunes and downloading it, any updates and updates for your tracker to get started, best be done at the beginning of your billing cycle.
The watch and mobile will not use data plan to communicate with each other; but your mobile does periodically talk with our servers to store your history so some sort of data plan is required.
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
