11-29-2018 19:33
11-29-2018 19:33
My Versa screen will turn on for a couple seconds and then half the screen will turn black. Then everything’s starts to fade away. I only had the Versa for a day. I tried restarting the Versa but it didn’t help.
Best Answer11-29-2018 19:37
11-29-2018 19:37
@RandomGuy7767 Try performing factory reset. Go to Settings app on your Versa, scroll down to About, tap it and scroll down to Factory reset. This will erase all data on your tracker and you will have to set it up again. You will have to delete Versa from your account in the Fitbit mobile app and from your Paired devices list in your phone's Bluetooth settings.
If you are unable to perform factory reset from the Settings app, try using 3-button method:
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
11-29-2018 19:43
11-29-2018 19:43
Thank you very much!!
11-29-2018 19:45
11-29-2018 19:45
@RandomGuy7767 Let me know how it goes!
11-29-2018 20:26
11-29-2018 20:26
I tried the factory reset and the Fitbit screen just turned blacked and won’t finish installing.
Best Answer11-29-2018 20:28
11-29-2018 20:28
@RandomGuy7767 did you get the Set-up screen on your Versa?
11-29-2018 20:33
11-29-2018 20:33
Yes, however when the Versa is downloading the data, the screen will slowly turn black
Best Answer11-29-2018 20:41
11-29-2018 20:41
@RandomGuy7767 you should be able to monitor progress of the upgrade in your Fitbit mobile app. You may need to rely on that until upgrade is finished. Versa should be downloading the latest firmware (.24). I have a bad suspicion though, it might be a hardware issue. If the upgrade fails/does not resolve the issue, you will have to reach out to Customer Support to guide you through the next steps as you may need a replacement.
11-29-2018 20:42
11-29-2018 20:42
alright, thank you
11-29-2018 20:46
11-29-2018 20:46
@RandomGuy7767 Good luck! The good news is if it's a hardware issue, Fitbit CS is good about replacing devices.
