If you tap on the preset response it allows you to type your own. Also, if you tap on the different apps it seems to allow you to personalize each response to different apps. But I could be wrong. I haven’t tried that. I only changed the preset responses.
You click on your versa in the Fitbit app. Then on notifications. Then find quick replies. Tap on that then tap on one of the replies and you should be able to edit it.
