11-07-2020 21:16
11-07-2020 21:16
I can’t even get my screen to light up. The only way is by holding it down to access Alexa then I can pull it down from the top. Once i get into settings- it sits there and does nothing. It literally stopped working in the middle of the day. I have NO idea what has happened. And it’s less than a year old.
Best Answer11-08-2020 01:14 - edited 11-08-2020 01:14
Hi @sk323 have you tried a restart?
Taping the button once, should turn on the screen
A double touch of the finger on the display should also turn on the screen.
However let's hold the button in swipe left, or maybe double tap the button. Whatever is needed to get to the quick settings.
Make sure sleep is disabled.
instead of hijacking a thread with an unrelated question, I've moved your post.
Best Answer11-08-2020 03:22
11-08-2020 03:22
Last night I couldn’t even turn off the light on my versa. Would not dim and shut off at all. Ugh. So frustrating.
Best Answer11-08-2020 03:23
11-08-2020 03:23
Hi rich. Yes I did all that ☹️
