12-05-2019 04:02
12-05-2019 04:02
Hi,
My versa heart rate sensor stopped working and i requested a replacement. Out of curiousity is the replacement brand new or refurbished? If refurbished, does anyone know if it lasts at least a year? Not sure if i should opt for a discount on a new fitbit instead. Any insight would be greatly appreciated.
12-05-2019 04:08
12-05-2019 04:08
It could be new or refurbished. The warranty terms say: "replace the Product with a new or refurbished Product"
Best Answer12-05-2019 04:10
12-05-2019 04:10
Ok thank you!
Best Answer12-05-2019 10:03
12-05-2019 10:03
When you get the replacement. If it is a refurbished model, by law, it will say refurbished on the package.
Best Answer12-05-2019 10:15
12-05-2019 10:15
Good to know! Thank you.
