09-15-2018 18:59
09-15-2018 18:59
I accidentally hit reset on my versa. the only notice I can get on my Versa is "to start download the fitbit app" the Fitbit app has always been on my phone. How do get back to an operating versa.?
Best Answer09-15-2018 20:12
09-15-2018 20:12
Looks like you did a factory reset. What you need to do is open the app and remove (or delete) the Versa as a device that is linked to your account. Then in the app, tap on add a device and go through the same stuff you did before to link your Versa.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
09-15-2018 23:36
09-15-2018 23:36
Thanks for the advice, I get as far as "Replace your Fitbit Versa" then we go around in circles when I hit "Set up a device" back to "Replace your Fitbit Versa" . I will have a look at the "Help" section to see if I can find a way to get my Versa operable. Many thanks guys.
Best Answer09-15-2018 23:50
09-15-2018 23:50
We might be able to give more info if we knew the phone model,
I suggest removing the aversa from your phones bluetooth, restarting both the versa and the phone.
Yes it does sound like a factory rest was done.
09-23-2018 16:50
09-23-2018 16:50
Thanks Rich, my phone is a Samsung galaxy S5.
I thought I had just about got over the problem where in the set up I had reached step 2, 100%
however after the set up reached step 3, the notification stated "set up Failed"
When the same result happened 3 times I gave up.
04:49
07:44
09-24-2018
04:49
07:44
It's great to welcome you @robertrj, @Rich_Laue and @wtksk8r thanks for stopping by.
I appreciate all the efforts in trying to fix this issue and would like to know if you keep having problems pairing your Versa? If so, I recommend taking a look at the help article Why can't I set up my Fitbit device? and follow the instructions provide there.
Let me know the outcome. ![]()
