06-07-2021 09:20
06-07-2021 09:20
Is there any tool I can try to Reset a Versa?
My watch is unresponsive/dead after a bad update from FitBit and a failed Factory reset.
Fitbit support does not want to try to help (other than saying I need to buy a new one)
I see the device identification information when I put on the charger and plug it in my macbook.
So, can I force a firmware back into the watch through USB ?
06-07-2021 13:47
06-07-2021 13:47
Hi @Debosama the usb charger can't force a firmware update. Are you able to see it connected still to your app?
Best Answer06-07-2021 14:35
06-07-2021 14:35
No I can't.
In my attempt to do a full Factory Reset to try resolving the battery drain issue, I removed it from my app first. Then try the Factory Reset.
It's unresponsive since then, so I can't add it back to the app.
Best Answer06-07-2021 15:23
06-07-2021 15:23
This issue seems to have affected so many users.
Fitbit Support is not able to help (other than saying I need to buy a new watch)
I see the device identification information when I put the watch on the charger and plug it in my macbook.
Or is there any SDK / Developer tool that could be useful here?
Thanks!
Best Answer06-07-2021 15:29
06-07-2021 15:29
@Debosama moved your post from the SDK Development forum area to this thread. SDK Development is for independent developers of such things as clock faces.
Best Answer06-07-2021 15:37
06-07-2021 15:37
I think it's a good idea to ask these developers if they had tools that helps them during development that would be helpful here.
This issue being such a plague on so many users, it's worth it to get advices from a broader audience.
Best Answer06-07-2021 18:18
06-07-2021 18:18
Hi @Odyssey13 ! Nice to see you around. Thank you for your help.
@Debosama Nice to see you on the Community! Thank you for your information and efforts.
As you already contacted Support, they could verify the situation with your device. If they advised you to get a new one, it's because they could identify that your Versa cannot be used anymore.
If you have any doubt regarding your case, you can always reply to the last message received from Support so that they can check your case with you.
See you around.
06-08-2021 05:13
06-08-2021 05:13
I think the Support answer (buy a new watch) is simply unacceptable.
They can't declare the hardware of the watch dead without seeing it or connecting to it. (Unless they know it's really fried by that update, and should tell us, and replace it)
Also, I don't see how buying a new watch will solve the problem. I will get into a similar situation after some update again.
The device is now useless because of an update. The hardware was top shape two weeks ago.
If we could find a way to revert to the firmware pre-update using a USB connection, it's worth a shot.
I trying to help you (Fitbit) to find a way to resolve this for so many users. You need to own up to your mistakes.
Anybody talked to the Fitbit engineering team ?
I found Support wasn't helpful. This issue seemed out of their scripts.
If under warranty: replace the watch
If not: tell them to buy a new one.
Support shouldn't be about warranty only. They should help users resolve their issues even when warranty is out.
Fitbit shouldn't have the rights to make devices obsolete to boost their latest device sales.
But that's how we all feel right now.
06-12-2021 18:12 - edited 06-12-2021 18:13
hi mate can you still "see" the fitbit in the phones bluetooth pairing settings? you may be able to pair it still if it has some power and use the phone to reset or to set it up? I know on android phones it will pair and the app is showing a "add device" setting and using that i was able to start it. good luck.
