08-07-2019 18:00 - last edited on 10-21-2021 13:46 by LiliyaFitbit
While viewing a recent run exercise on my Fibit Versa app, I accidentally delete the exercise. Is there any way to retrieve it? Thank you.
08-07-2019 23:38
08-07-2019 23:38
Hi @hungster No, you cant retrieve it, but you can re add it manually in the app. The stats may be a bit off but it probably be much the same data.
Helen | Western Australia
08-07-2019 23:38
08-07-2019 23:38
02-28-2020 04:24
02-28-2020 04:24
But then you double count your steps as the original number is saved in your daily numbers.
Really is quite poor at how easy it is to loose this data.
04-12-2020 12:57
04-12-2020 12:57
This just happened to me. I simply went back through the work out, but skipped literally every interval. When I skipped the last one it asked me to rate the program like usual, then it took me back to my program home screen, and it was counted towards my progress! So happy! And also disappointed I had to "trick" the program to count a session I legitimately did.
It also did not change my stats in any other way.
Best Answer10-13-2021 14:09
10-13-2021 14:09
I just got a Versa 2 and have lost workouts twice because it is so easy to accidently delete things. Found out today when it happened again that YOU CAN RETIEVE the info. Just start another exercise session on your fitbit and stop it. The lost info will come back up in the app. along with the new session. Just delete the "new" session you created.
02-06-2022 12:39
02-06-2022 12:39
Didn't work for me. Although I never accidently deleted the exercise, Fitbit did. I opened the app on my iPhone, synced the data and the exercise was there, synced it again and it disappeared and was no longer in my sessions. Now it's permanently gone.
12:41
08:03
AndreaFitbit
02-06-2022
12:41
08:03
AndreaFitbit
PS. Just happened again. Did a 10 min jog on the spot to see if it would be recognized, it was. Closed the app, synced it and now that exercise is gone too. Do better Fitbit. This is ridiculous.
Adding an exercise manually increases your step count and adds steps you didn't take because the one thing that is retained from the deleted exercise is the steps you accumulated. Not to mention, adding an exercise completely skews all other data. Would not recommend and it isn’t a solution by any means.
Moderator edit: updated post.
Best Answer06-20-2022 11:43
06-20-2022 11:43
Just tried this with my Ionic and it worked! Thanks
