hello! I did search the topic and found some information, but it seems a few years out dated. I thought I’d resurface the subject.
It would be nice to have a GPS rollerblading option. Similar to bike. I can manually enter roller blading after but the calories burned is significantly different than the bike. Also, no option to put on a distance with roller blading.
in addition to the option not being Ab Laila or for GPS. If I Do log as bike I can’t change to rollerblading.
Would super helpful if we got this added!
thank you!
