11-15-2018 16:38
11-15-2018 16:38
Hi there. I bought my versa this year. After one month issue I had a screen issue and fitbit got it replaced.
Now the screen has been "blacking out" on me but the green HR sensor is still blinking when I take the watch off my wrist. Can anyone help pleassssse?
Second time am having problems with with my versa.
Thanks
Best Answer11-15-2018 16:55
11-15-2018 16:55
@Pravesh Have you tried rebooting your Versa several times? Press and hold the left and bottom right buttons until Fitbit logo flashes. If this doesn't help you might have to perform factory reset. Please sync your tracker first as this will wipe the data. If you can use (see) the screen, tap on the Settings app on your Versa, scroll down to About and tap Factory reset. If the screen of your Versa is dead, please perform factory reset using the buttons on your Versa as described below:
You may need to attempt the reset a few times to find the optimal times. Trying holding the buttons longer, as long as it's needed for the vibration to appear.
Best Answer11-15-2018 19:03
11-15-2018 19:03
I tried all but in vain.
Best Answer11-15-2018 19:05
11-15-2018 19:05
@Pravesh I'm afraid at this point you should contact Customer Support. It might be a hardware issue.
