09-16-2020 18:57
09-16-2020 18:57
I have a Versa lite, and the screen seems to be dimmer (less bright) than when I first got it a year ago. Anyone else having this problem? Better yet, is there a control that can increase the brightness.
Best Answer09-17-2020 03:10
09-17-2020 03:10
Hi, @Shkane , yes, there is a setting for brightness on the Versa Lite (and other Versa smartwatches).
On your Versa swipe left until you come to “settings”. Tap in settings and you will see the option to change the brightness: max, auto, normal and dim.
I hope this helps. Welcome to the forums!
ps you posted your question in the Versa 3 forum. As the Versa 3 has not yet launched, I have moved your question to the “pther Versa smartwatches” section of the forum in order to keep the conversations together and the forums organised.
09-17-2020 03:10
09-17-2020 03:10
09-17-2020 06:29
09-17-2020 06:29
09-17-2020 12:57
09-17-2020 12:57
