01-11-2019 00:52
01-11-2019 00:52
Has anyone else had little feet appear in the bottom left hand corner of the versa screen? the only way I was able to remove was to change the watch screen
01-11-2019 01:16
01-11-2019 01:16
@Kymmunro I'm assuming it's specific to the clockface design you used. You can browse all clockfaces in the Fitbit mobile app (just tap on versa icon then clocks) and pick one you like!
Best Answer01-11-2019 01:16
01-11-2019 01:16
Best Answer01-11-2019 11:53
01-11-2019 11:53
@Marrrmaduke thanks for your reply, yes i was thinking that it had something to do with the clock face i had chosen, although the screen was black with just the feet in the corner so nothing else was displaying, so was thinking something was not right.
Best Answer01-11-2019 15:09
01-11-2019 15:09
@Kymmunro I see. Let me know which clockface you chose now? Hopefully it's better than the old one. 👍🏻😊
Best Answer01-11-2019 18:23
01-11-2019 18:23
@Marrrmaduke The one I had on when screen started playing up was Sliding Text Improved, the one I have now is purplelights, fingers crossed it was just that that was the issue.
Best Answer01-12-2019 21:06
01-12-2019 21:06
@Kymmunro Awesome. If you experience any other issues, just shout! 😄 Have great weekend. 🙂
Best Answer01-13-2019 04:42
01-13-2019 04:42
Really,and i'm planing to get one for myself
