05-10-2018 06:12
05-10-2018 06:12
Hello.
Is anyone struggling with the screen coming on too often and draining the battery.
I've turned the 'Screen wake' function off, which stops the twist of the wrist turning it on. But it still triggers whenever it senses a 'double tap' like movement. I've set the time-out to 10 seconds and the brightness to the minimum, but it's still eating the battery life when I don't want the screen on.
I'm on firmware version 32.32.4.19 which I assume is the current version?
Thanks.
05-12-2018 06:56 - edited 05-12-2018 08:05
How you doing my friend @dreamland? Welcome!
Sorry to hear that you're having issues with the battery of your Fitbit. Thanks for those steps you've tried already, good job! You didn't mentioned the name of your Fitbit, but that version was the first one that was released for Fitbit Versa. The latest one is version 32.32.10.20 released three days ago, in case that you haven't updated it please do so; you can see the steps to follow in this article.
You can also, check the tips on this post on how to get a better life time for your Fitbit battery. I hope those steps helps the functionality of your Fitbit screen! Remember that you can also turn off the screen when not in use, briefly cover the watch face with your opposite hand; since there is not another option to just turn off the display and use only the buttons.
BTW I've moved your post the Versa board, to increase the options for you to get appropriate responses to your inquiries.
See you around.
See you around.
