05-11-2018 08:30
05-11-2018 08:30
I just bought the Versa and I seem to be having a lot of issues with it. It is not tracking my sleep at all and doesn't sync properly to multiple devices. I have a Samsung Galaxy 8 phone so compatible. Did I get a bad one or are these just problems it has.
Best Answer05-11-2018 08:42
05-11-2018 08:42
Try a factory reset and see if that fixes the issues.
From the versa, settings, about, factory reset.
Best Answer05-11-2018 11:13
05-11-2018 11:13
Best Answer05-11-2018 17:42 - edited 05-11-2018 17:42
After a factory reset, you must reinstall the device as a new device in the app. Remove the old device first.
Good luck
Best Answer05-12-2018 04:52
05-12-2018 04:52
Best Answer05-12-2018 06:24 - edited 05-12-2018 06:25
Mine tracks my sleep and appears to be very accurate, even counting naps and what not. It does add up to 200 steps in my sleep depending on how restless I am, but that appeared to be within normal range given how much I tend to move around and throw covers and what not.
So I think something is wrong with yours. Anyone whose manually inputting sleep has something not quite working on their versa.
