04-29-2018 01:47
04-29-2018 01:47
Hi
Does anyone know where to find the serial number on the versa?
thank you
04-29-2018 01:50
04-29-2018 01:50
I nelieve it is on the box rather than the actual watch.
Helen | Western Australia
04-29-2018 01:54
04-29-2018 01:54
04-29-2018 01:56
04-29-2018 01:56
Oh dear, then I am no help. Hopefully someone who knows will come along. Otherwise contact Support (link in my signature ) - I am sure they will be able to help you.
04-29-2018 01:58
04-29-2018 01:58
Thanks hun
04-29-2018 03:08
04-29-2018 03:08
@HannahJJI can only presume the serial number is the number you see at the end of this link when your click on Settings and then click on your Fitbit model.. I have xxx'd some of the numbers..
https://www.fitbit.com/settings/device/tracker/6a2xxxf89a1b
But has no relationship to the barcode on my Ionic box... Maybe this is just a link to my account..
@EdsonFitbitYou posted in this link in 2016 where we can find our Serial Numbers..
12-26-2019 07:28
12-26-2019 07:28
Just figured this out based on my box and my link. The serial number is on the box, under the barcode....and it is also scrambled in the URL when you select the device on the fitbit.com website.
For example if the bar code number on the box was: 012345C67891....the link has it scrambled as: 9178C6452301, other words 2 digits pairs going Left to right, but starting from the right side. Hope that helps and makes sense for someone else!
01-02-2020 11:01
01-02-2020 11:01
Hello, do you know if the serial number can be located in the actual fitbit? I lost my Versa 2 two days ago and I believe someone stole it. I looked in the marketing section on Facebook and found a guy selling a Versa 2. Anyway, to make a long story short, he asked for the serial number to verify that it's mine, but I thought you can't locate the serial number in the actual product. I think it may be mine and he thought I'd be dumb enough to give it to him (I have the box with serial number) so he can active it with the serial number. - V
07-20-2021 11:42
07-20-2021 11:42
This right here is the answer. Thank you so much.
