03-20-2018 06:13
03-20-2018 06:13
How strong is the Versa's vibration of the silent alarm? The original Charge was awesome, and would wake me up, but when I was forced to update to the Charge 2 I've found that I share the frustration of many in that the vibration is much weaker.
How does the Versa vibration compare with the Charge, Charge 2, and other products?
03-20-2018 10:21
03-20-2018 10:21
On page 21 of the manual, there is a picture with a "Vibrations->Strong" setting, so I imagine it can be set strong enough.
https://staticcs.fitbit.com/content/assets/help/manuals/manual_versa_en_US.pdf
03-20-2018 09:23
03-20-2018 09:23
I have this question too.
I still use Charge HR, it's awesome as an alarm.
Charge 2 was too weak, I returned it for this (and several other) reason.
03-20-2018 09:29
03-20-2018 09:29
If it functions like the Ionic (which I believe we can, I am using the new OS) you can change vibration from normal to strong. Strong did the trick for me.
03-20-2018 10:21
03-20-2018 10:21
03-20-2018 10:54
03-20-2018 10:54
Thank you. That is great information. Is there anyway someone from @Fitbit could let us know if there is a ranking or range of comparison between the Charge HR, Charge HR 2, and the Versa vibration settings? What if "strong" is really just the same level as the Charge 2. That would be dissapointing.
03-20-2018 11:20
03-20-2018 11:20
Strong is much more dramatic on my Ionic than the vibration on my Charge 2. Very noticeable difference. Hope that helps.
03-20-2018 14:58
03-20-2018 14:58
Hi! @james-async
There is not any ranking of which trackers/watches would be strongest that I can provide. What I can say is we have taken into consideration the feedback for vibration and have made improvements. Hence, the option to increase the vibration strength from "normal" to "strong" on Ionic and Versa. If you'd like to give Versa a try, please go for it! Our return policy provides a 45-day timeframe which should be enough time for you to test out all the features important to you. Let me know if I can help with anything else!
03-21-2018 15:21
03-21-2018 15:21
The "strong" setting on the Ionic is VERY good -- it's far stronger than the Charge 2. I can't imagine anyone being unhappy with the "strong" setting's action.
04-28-2018
19:06
05:22
AlejandraFitbit
04-28-2018
19:06
05:22
AlejandraFitbit
I have a Fitbit Blaze and the vibration for text notification is perfect, it is strong, and you can literally hear the vibration. I checked the vibration settings on the Versa, it was at normal. Selected strong hoping it would feel different and it did not. It literally only fells a bit stronger. The alarm setting on the Versa is very strong and just about the same as my Blaze. Maybe my watch was a dud, but it needs to be a lot stronger. I do not even feel it. Meaning I never notice when I get a notification. Disappointed in this.
05-02-2018 05:38
05-02-2018 05:38
It's great to see you here @Zumbzbarre.
Thanks for the feedback provided regarding the vibration of the Versa. Have you tried to restart your watch? If you haven't, I recommend restarting it by doing the following:
Let me know the outcome.
05-06-2018 17:57
05-06-2018 17:57
It seems to be stronger than it was before. It is noticeable. Not as strong as sting as my Fitbit blaze though.
05-06-2018 19:58
05-06-2018 19:58
I actually am experiencing the same thing, I barely feel the vibrations
05-14-2018
07:11
11:48
MarcoGFitbit
05-14-2018
07:11
11:48
MarcoGFitbit
Hi,
I miss most of the notifications due to weak vibration.
I've changed it to strong already in settings and it is weak still.
Is there any other chance to make silent notifications stronger?
I'm sorry to say, but if it will not allow me to set some multiple vibrations or any other way how to make it stronger I will have to leave it 😞
05-16-2018 11:51
05-16-2018 11:51
Hello @MichalX, have a warm welcome to the Fitbit Community, it's great to have you on board.
We really appreciate our members's input and feedback and I would like to thank you for yours. I understand how important it is for you to have a stronger setting for vibrations in the Versa. Our team is always looking to improve the Fitbit experience and I would like to encourage you to submit your insight as a suggested idea, where members of the Community can comment and vote for it so it can be implemented in the future.
Feel free to share your suggestion with your friends and family to add more votes and comments, this is the best way to make your voice heard and get the attention from our development team.
I hope this can be helpful, if there's anything else I can do for you, please feel free to reply.
07-31-2018 12:05
07-31-2018 12:05
VERY WEAK ALARM! Twice now I have missed waking up on time because I can BARELY feel the vibration of the versa alarm. PLEASE do something about this.
Never had this issue with the Charge 2 Special Edition.
I am regretting upgrading to this Fitbit Versa.
07-31-2018 12:49
07-31-2018 12:49
@iamrudes Did you try setting your vibration to strong in the settings app?
07-31-2018 13:23
07-31-2018 13:23
you rock! solved! thanks so much!
01-04-2019 13:06
01-04-2019 13:06
All of a sudden the strong notification setting has become very weak on my versa. Any reason to this and solutions?
02-10-2019 15:11 - last edited on 10-16-2019 19:00 by LiliyaFitbit
I recently had 4 lumbar vertebrae fused and need to walk as much as possible. I bought the Versa for the reminder to walk 250 steps every hour. I like the watch but either I do not get the vibration reminder or I don’t feel it.The watch is set to strong and I can feel ( not very strong) when I swap from normal to strong. Tried suggestions from blog , reset watch via Fitbit chat, no luck.
Do I give up and return it?
I’ve spent too much time trying to fix it
Guess I’ll used trusty hourly alarms on I phone. They are loud and annoying but they work.
sincerly,
03-20-2019 15:12
03-20-2019 15:12
I have the Inspire HR. The vibration is also very weak and I can't find instructions to strengthen it.
