12-10-2019
05:11
13:47
RicardoFitbit
12-10-2019
05:11
13:47
RicardoFitbit
I recently got the Versa 2. I noticed when I get up in the night to pee it captures my sleep after that as my total sleep for the night (e.g., 4 hours sleep vs the 6 hours I actually got). Is there any way to ensure the device captures the full sleep?
12-11-2019 13:47
12-11-2019 13:47
Hello @LarryL2, welcome to the Community Forums!
Thanks for bringing this to my attention. Let me share with you that autodetection is based on your movement. When you haven’t moved for about an hour, your device assumes that you’re asleep. Additional data—such as the length of time your movements are indicative of sleep behavior (such as rolling over)— help confirm that you’re asleep. Also, morning movement tells your tracker that you’re awake and this may be the reason your sleep tracking gets interrupted when you go to the bathroom.
That being said, if you haven't already done so I recommend you to check our help article: How do I change my sleep history? to edit your sleep logs accordingly.
Let me know if you have any additional questions.
