05-10-2020
05:10
11:37
DavideFitbit
05-10-2020
05:10
11:37
DavideFitbit
Bought a Fitbit Versa 2 last week and most stuff seems clear but the alarm option don't function proper.
Bought the Versa 2 because of the smart-wake option, which i thought would be there. However when I set an alarm on the watch itself the option to toggle smart-wake isn't there, all I can do is select time and which days. Any advice on this? Looked on the mobile phone app and can't find it there either.
any tips/help?
Right after you add an alarm, there is a check box for "smart wake" right under the time and on/off boxes, just above where you scroll down to see the days for it.
If you don't see it there, and just set it up, maybe it shipped without it and is in a firmware update you should automatically get soon.
07:01
11:38
DavideFitbit
05-10-2020
07:01
11:38
DavideFitbit
thank you for your message,
the Fitbit Versa 2 (under settings ) says its a version 35.68.9.15
do you have any idea how to update this, or is this the most recent version?
Best AnswerShould Smart Wake be available as soon as you start using your Fitbit? Or does it take a while to assess your sleeping patterns before it becomes accessible? Everything I've read about it says it should show up as a tick box option (above the days of the week) when you're setting your alarm, but mine doesn't have it at all! I just bought my Versa 2 four days ago so it's brand new and doesn't need an update!
