01-05-2019 06:45
01-05-2019 06:45
So it's been about six months since there was a post asking if the Sony Xperia XA2 synced ok with the Versa.
I'm looking at buying a Versa but I'm really needing to know if it's syncing as I'm guessing it would be pointless buying it otherwise, especially as the phone is only four or five months old so I cannot justify replacing it so soon. I got told by Fitbit cut n paste support replies that is not on the supported list, something I'd mentioned in the ticket (sigh), but I've read that's not the be all and end all in compatibility etc.
I'm running Android 8.
Thanks in advance for any advice.
Best Answer01-05-2019 09:05
01-05-2019 09:05
Hi, the XA2 is indeed not in the list of supported devices, but this does not mean necessarily that it will not sync with your device. See this article: How do I set up my Fitbit device, hope this helps. Good luck.
