01-03-2019
13:09
16:31
DavideFitbit
01-03-2019
13:09
16:31
DavideFitbit
Before I did the recent firmware update the battery in my Versa would last 4 - 5 days. Ever since the update it only last 2 days. I have turned off anything that would use up battery and it is still dying out fast. Help please
01-03-2019 13:43
01-03-2019 13:43
Hi, which Clock Face are you using? One of Fitbit itself or a Third Party one. If the last, please send me the name of it. Some of them can cause a diversity of problems, battery drainage is one of them.
13:57
16:31
DavideFitbit
01-03-2019
13:57
16:31
DavideFitbit
I am using a Fitbit face. I had read that the other ones can drain the battery too fast.
Thank you,
Andrea Andersonwww.aahandwovens.comwww.etsy.com/shop/AAHandwovenwww.synchrosuits.com
Best Answer01-03-2019 13:59
01-03-2019 13:59
Hi Anrea, which one are you using, the default one or another one?
Best Answer01-03-2019 15:44
01-03-2019 15:44
Best Answer01-03-2019 15:50
01-03-2019 15:50
Hi, that should not be the problem of draining your battery after the update. First of all I would advice you to reboot your Versa twice by pressing and holding the right lower buttons together untill you see the Fitbit logo and release the buttons. If that does not do the trick see How to control your battery's life . Good luck.
Best Answer01-03-2019 21:32
01-03-2019 21:32
You may be lucky since I downloaded the new firmware my watch is not working at all no screen or anything, I have been in touch with Fitbit tried there suggestion and still have no watch I only purchased the watch on the 16/10/18 so I am not very happy.
Best Answer01-03-2019 22:05
01-03-2019 22:05
Same thing here. Since the update, battery is alive for 8 hours max.
Best Answer01-05-2019 09:01
01-05-2019 09:01
Best Answer01-05-2019 09:09
01-05-2019 09:09
Hi, I would advice you to call Customer Support, cause 48 hours is too short for a watch of which it is stated to last 4+ days. Mine lasts 6 days on one charge, but I'm using a clock face of only 12 kB and do not have music on it. Good luck!
