01-26-2022
05:56
20:34
01-26-2022
05:56
20:34
I can only Choose between hiking walking and running. I want to do a work out. It is Saïd i van choose from 20 different kinds of sports but how?
I have a versa 3.
It sounds like you are starting from the phone app. Try using the Exercise App on your Versa 3. From main clock face, scroll right through apps to 'Exercise' and tap that. Then scroll down through the different choices. After you select your choice, you can swipe up from the little arrow at bottom screen to see more settings for that particular option.
Best AnswerIt sounds like you are starting from the phone app. Try using the Exercise App on your Versa 3. From main clock face, scroll right through apps to 'Exercise' and tap that. Then scroll down through the different choices. After you select your choice, you can swipe up from the little arrow at bottom screen to see more settings for that particular option.
