01-03-2019 08:33
01-03-2019 08:33
Why are my steps not showing up on my Versa
Best Answer01-03-2019 13:08
01-03-2019 13:08
@elflakey When you swipe up on the main screen of your Versa (to open Today app), can you see the steps taken there? Or do you mean you cannot see them on the main screen? In that case which clockface are you using? Not all of them show all stats. Simply, change the clockface to one that shows steps. 🙂
01-03-2019 13:08
Best Answer01-03-2019 13:49
01-03-2019 13:49
Best Answer01-03-2019 13:51
01-03-2019 13:51
@elflakey All is well, then? 😄
Best Answer01-03-2019 19:10
01-03-2019 19:10
Yes, thank you for your excellent help!
Best Answer01-04-2019 13:37
01-04-2019 13:37
@elflakey I'm glad I could help! 😄
Best Answer01-07-2019 07:19
01-07-2019 07:19
Hey,
I am having the same issue my versa is showing 0 steps and I swiped up still no steps.
How can I fix the problem??
Allie
Best Answer01-07-2019 07:22
01-07-2019 07:22
Also you mention changing clock,face 😟 it's been working just fine and I have no clue how to change clock face.
Best Answer01-07-2019 07:31
01-07-2019 07:31
Ok this is weird, it just started working..
Best Answer01-07-2019 18:44
01-07-2019 18:44
@1nanny4u I'm glad. Btw, if you have never changed the clockface, then it means you have fitbit original clockface installed - this wouldn't be an issue then. Versa probably needed to sync. I'm glad all is well.
Best Answer02-16-2019 15:36
02-16-2019 15:36
I'm having the same issue my steps say 0 but when I go into the app all my steps are there. I have tried restarting my watch. Nothing
Best Answer02-17-2019 20:12
02-17-2019 20:12
@Mbatye You mean on the main screen? If you swipe up (to open Today app) on the main screen of your Versa, can you see your steps there? If you can see them in the Today app, then it's a problem with your clockface. Try to reinstall it or choose a different one.
