05-15-2023
23:41
11:11
AndreaFitbit
05-15-2023
23:41
11:11
AndreaFitbit
Hi there, wonder if anyone can help me. I purchased a stitch (as in Lilo and Stitch) clock face last year or possibly the year before, I’ve been using it fine until one day last week it disappeared and the standard Fitbit clock face appeared and now I can’t even find this clock face in the gallery section or on my faces section. Had this happened to anyone before?
Many thanks 😊
05-15-2023 23:55
05-15-2023 23:55
Hi @Susie80R - when you go to the Gallery tile in the Fitbit App if it is missing you may have done a factory reset, or loaded other faces that removed it.
While on that screen if you search for it and it does not appear, either it was removed from the Gallery or it has a different name and you may need to search for it by it's features.
It should be noted that it may have been made for an older watch and not available for the Versa 3 - see this link which has 2 clocks with Stitch in the name but not for a Versa 3.
05-15-2023 23:55
05-15-2023 23:55
