01-24-2019 06:49
01-24-2019 06:49
For some reason I can't get my Versa to connect and update on mu LgV20. This is crazy ridiculous . Any help would be great
01-24-2019 12:47
01-24-2019 12:47
Hi, as per this list your LGV20 is not supported yet by Fitbit., therefore your problems. In the meantime, untill Fitbit supports your phone, you can use and sync it with you PC/Laptop via Fitbit Connect. How to do that read the article "How do I setup my Fitbit device". Click on the link and once you're on this page, press "Trackers and Watches" and the page will expand. Scroll down to directly underneath the first video and read the paragraph about Fitbit Connect.
01-24-2019 14:22
01-24-2019 14:22
I have the LGV20 and I got the app to work but it does not sync all the time. Have to uninstall and reinstall all the time. I will probably have to get a different product that works with the LGV20 phone since Fitbit will not work correctly.
01-24-2019 14:42
01-24-2019 14:42
See my post above yours.
01-24-2019 16:22
01-24-2019 16:22
01-24-2019 16:38
01-24-2019 16:38
Hi, as I do not work for Fitbit or have any connection with this Company, I do not know when it will be supported. Out of own experience, it will take a few weeks.
01-24-2019 16:41
01-24-2019 16:41
01-24-2019 16:52
01-24-2019 16:52
12-02-2019 10:33
12-02-2019 10:33
Just bought the versa 2 and using my lg v20.. and sync issues galore, even set up problems, with fitbit only "officially" supporting a certain number of devices, they are loosing business, deciding whether or not to keep it or switch to something different, I really want it to work but after factory resetting my phone and it still not working well...
