Sync notification bar mia
ANSWERED
When I first got my fitbit versa there's was a constant sync notification. But up till a week ago it just disapeared and now my versa doesn't want to sync for hours. What is going on?
1 BEST ANSWER
Accepted Solutions
What you can try is:
1. close the Fitbit app
2. deinstall it from your device
3, restart your phone
4. reinstall Fitbit again and, of course, enable BT
See if that solves the syncing problem.
7 REPLIES 7
Hi, do you have enabled "continuous synchronization" in the Fitbit app and "always connected" also? yo also can enable "Quick Display".
I have all day sync and always connected on. I don't know where quick display is
All of them are turned on so idk.
Directly above WiFi settings.
All are on so I don't get what's wrong
Seems that worked  thanks
