05-14-2018
16:21
08:08
AlejandraFitbit
05-14-2018
16:21
08:08
AlejandraFitbit
The Fitbit app sucks, the Versa doesn’t sync the sleep and doesn’t record the 250 steps goal.
08:12
10:15
05-16-2018
08:12
10:15
It's great to see you around @Abbeyrosie.
If your Versa isn't syncing with your Fitbit app, I recommend taking a look at the Having trouble syncing? post and follow the instructions provided there. Now about the 250 steps per hour, have you checked if you have this feature on? If you haven't, I suggest doing the following from your Fitbit app:
Hope to hear from you soon. ![]()
Best AnswerI never could get the versa to work correctly I tried everything even on the phone with Fitbit so because of that I returned the versa I wish they would get the fit bit app to sync play with the versa I’ve tried everything
