The battery on my Versa 2 is draining quickly
My Versa 2 battery is lasting less than 24hours. Does Fitbit replace devices? It is less than 1 year old.
2 REPLIES 2
It is most likely not a watch problem.
It probably occurred after a firmware update or Fitbit App update or different usage, or even a clock face update.
It is/has been a known issue with the App. To confirm the source of the problem try turning off the phone's Bluetooth.
Shutdown the watch, wait 10 seconds and place it on charge to start it and fully charge it. Then see how long it lasts.
If its ok, then the App is the culprit.
Probably best to contact Fitbit Support directly if its persistent. They may be able to help you.
Thanks! I will give that a try
