Hello, I bought Fitbit Versa and I have a minor problem. I need to set the time because it is set an hour later. I tried to go to Advanced settings and set the time automatically and sync them and nothing happened, what should I do? Thank you for answer.
It might be that your timezone is set incorrectly in your profile settings at https://www.fitbit.com/settings/profile
