To Versa or not to Versa?
ANSWERED
I had the Blaze, didn't pan out so well. Thinking about the Vesa now. Based on your personal experience, would you recommend it?Smiley Happy
1 BEST ANSWER
Accepted Solutions
Hi, based on my personal experiences with the Versa, despite all the negative posts, I will certainly recommend it. It's an amazing device, whic works flawlesly for me and with the right settings, the battery will last for 5 to 6 days. What phone are you using? Just to know whether your device is compatible with Fitbit.
9 REPLIES 9
That would depend, does the Blaze meet your expectations?
What is it that you want from the Versa?
Can not say if I would recommend without knowing more about your needs.
Hi, just a note: the Blaze is not a Smartwatch, the Versa is. That might be his consideration to change devices and wants to know our personal experiences with the Versa.
I said,... based on YOUR personal experience.
I like how you explained that one of them isn't a smartwatch, those kinds of things make a big difference. You'd recommend it, that's also good.Smiley Happy Amazon, and other sites like businessfincialpost.com and more call the blaze a smartwatch which confuses people who are new to this concept. I'd say it's a smartwatch-looking fitness tracker.  Compatibility won't be an issue for me.
Hi, you're right, the Blaze is a "smartwatch-looking fitness tracker" (and a very nice product - used it myself for almost a year), but it's surely not a Smartwatch. The first real Smartwatch build by Fitbit is the Fitbit Ionic, the successor of the Blaze. Just one question: Why is compatibility no issue for you, just curious?
Hi, thank you😊 All that means is, I have access to phones that can pair
with the specs of the Versa. So compatibility won't be my hang up, no pun
intended. lol
@Niecy17 since you already have a Fitbit the Versa well connect the same way
Fitbit also makes the ionic with it's built in GPS if you used the GPS a lot with the Blaze.
Now if the Blaze seemed to be more than what your needs are, than the Charge 3 might be with looking into
Based on your personal experience, what do you have to say about the Versa??
