10-13-2019
17:12
14:01
RicardoFitbit
10-13-2019
17:12
14:01
RicardoFitbit
Hello, I have an android Note 9 synced to my Fitbit Versa. I just updated the Fitbit and now no touch or scrolling will work on the screen. My physical buttons work. My heartrate monitor is working. I am just having trouble with the screen not registering any tapping.
10-14-2019 14:00
10-14-2019 14:00
Hello @Krazykurlz, welcome to the Community Forums!
Thanks for bringing this to my attention. If you haven't already done so, I recommend you to restart your Fitbit Versa following the next steps:
Keep me posted and let me know if you have any additional questions. By the way, I've moved your post to the Versa board.
10-18-2019 08:59
10-18-2019 08:59
Thank you for the reply! The restart did help but new problems followed. I am getting a replacement. Thank you for your help.
10-23-2019 00:18
10-23-2019 00:18
02-04-2020 10:20
02-04-2020 10:20
Hello, I am having the same issue. I’ve tried the restart several times with no luck, any other suggestions?
02-04-2020 10:30
02-04-2020 10:30
Mine is doing the same exact thing. This morning I attempted to reset using the three buttons on the Versa as the instructions on this site say to do. After that I got a red X and it says "data not cleared. Sync and try again". So, I next contacted Fitbit support and we got it working by unpairing the device on my phone and then repair it again. When you do this, it is like setting up a new device again. After the setup, the Versa was unresponsive for a little bit until I connected to Wi-Fi. Once I did that, it was acting like normal. Around lunch time today, it started acting up again. Tap the screen, nothing would come one. When it did finally come on, the swiping through the screens did not work. Finally, it went back to the red X error mentioned above, and I had to start this whole process over again in order to get it to work.
