Fails to sync on Android or iPad
And now the time is inaccurate also. Hoped firmware udate would solve syncing issue --- it did not, but seems to have caused the time issue which gets worse by the day --- is there a way to determine if the firmware update installed properly?
@anng90, welcome to our Fitbit Community. I'm sorry to hear that your Fitbit Versa Lite is not showing the correct time and won't sync.
Regarding your inquiry, a check mark appears when the firmware update is complete.
I'd like you to try the troubleshooting steps that are listed in this help article. After this, monitor your watch and see if the issues get fixed.
Keep me posted on the outcome.
Best AnswerSync problem continues - it randomly syncs---the help suggestions did not help. Is there a way to check the Bluetooth? I also do not receive notifications (call or message) on my versa lite since the firmware update.
Is there a way to confirm the successful completion of the update?
